Hi, I would like to know what is the best
7th gen processor for my motherboard ASROCK B250M PRO4, because my current one i5 7500 seems to be bottlenecking the sistem in latest games...
You should describe your problem and why you think it's bottlenecking.
What are the rest of your compoents?
Rest of my components are:
16GB RAM (4x4GB) Kingston HyperX Fury 2133MHz
250GB SSD Samsung 850 EVO
2x1TB WD Blue
AMD RADEON XFX RX 480 RS 8GB
CPU MAX TEMP around 60°C
GPU MAX TEMP around 72°C
and as mentioned Motherboard is ASROCK B250M PRO4, and CPU is Intel i5-7500 ( normal version not K )
oh and I notice in games like Battlefield 1, PUBG, and other my CPU is always at 100% usage and sometimes stutter, not often. Other components I believe are stong enough for everything but CPU is 4 cores and 4 threads...
