Basically i asked a question in GPU forums about running a GTX 980Ti and somebody said to save me money i should upgrade my processor from a i7-950 to an extreme version
I was looking around for one and come accross a i7-990x
Would this do the job along with 12GB corsair veagence ram and a 750watt psu ?
I just want 4K gaming without having to replace my whole rig but if i have to replace my cpu as well as upgrade from 2x GTX 480s im already looking at atleast £525 for a 980Ti and atleast £500 for the proccessor thats knocking a grand already but i can atleast get £100 for 2 480s and im not sure what i would get for an i7 950 cpu.....
What would you guys recommend to get a 4K rig with what i already have. Shall i just risk it and buy a 980Ti see how it runs first then maybe upgrade my processor later? Or is that really such a bad idea? my 950 is Overclocked to 4.0ghz stable
Would it be such a big bottleneck? Would a 990x be a good idea?
Just found a Xeon X5690 which is like £200/£300 cheaper used so wondering if this would be a good idea.
http://www.ebay.co.uk/itm/Intel-Xeon-Processor-X5690-3-46-Ghz-Six-Cores-SUITS-R610-R710-R810-DL380-G7-/361239175177?pt=LH_DefaultDomain_3&hash=item541b886009
Says something about making sure my board can take a 130w cpu not sure if it can
just looking here i dont see this xeon chip as supported though for some reason?
http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=3449
But i found this one is but will it do the job?
Intel Xeon W3690
thanks
Intel Xeon W3690
thanks
