Best PSU and graphics card upgrade for emachines et1331g-03w
Rolandn9ne
4
Looking to upgrade my emachines PSU and graphics card, currently have 300w PSU and integrated Nvidia GeForce 6150 SE, currently using AMD Athlon II 235e 2.70 GHz. Looking to play dota2 and smite mostly
cam go a bit cheaper on the psu but there are not any decent sales right now on psu's
Video Card: EVGA GeForce GTX 950 2GB Superclocked Video Card ($129.99 @ Newegg)
Power Supply: XFX XT 500W 80+ Bronze Certified ATX Power Supply ($60.98 @ Newegg)
Total: $190.97
Generated by PCPartPicker 2016-02-10 15:11 EST-0500
few bucks less for this xfx model and 50 extra watts. still good quality unit.
but the 950 is about what you're looking at for that budget. good card that gives most of the 960 performance for a lot less cash.
do you have a budget in mind? you can upgrade to anything you want really and only limited by your budget. i'd suggest something like a gtx 960 since your cpu is so weak. anything more and you won't get the full benefit of it due to being held back by the cpu.
you could do a 960 and a new psu for probably about $250 or so. you can go for more if you plan on upgrading in the future and then you won't have to replace those parts. but if you won't be getting a new cpu and such within a year it would not be worth it to go for more.
Should have mentioned my budget, trying to keep it on the low end of price, like around 150-200 for both psu and card, any suggestions that are compatible with my computer for that?
PCPartPicker part list: http://pcpartpicker.com/p/4Q2RZL
Price breakdown by merchant: http://pcpartpicker.com/p/4Q2RZL/by_merchant/
Power Supply: SeaSonic 450W 80+ Gold Certified Semi-Modular ATX Power Supply ($73.99 @ SuperBiiz)
Total: $203.98
Generated by PCPartPicker 2016-02-10 14:40 EST-0500
Not sure if you are in the US or not but here you go.
Total: $190.97
