Best PSU/Case for i5-4670K and GTX 770
robby2009
This is a two part question. I am doing my first build in several years, so I have fallen a bit behind on the latest tech, but here we go. I am planning on doing an i5-4670K and an ASUS GTX 770.
1) I am looking at a Seasonic 660W PSU. Would this be sufficient to keep this rig going smoothly?
2) Will the GTX 770 fit in a typical mid tower? I have a GeForce 9600GT in my current computer, but I know the 770 is going to be bigger than this one. I'm just not sure HOW much bigger.
660W will be enough.
A 770 should fit in a mid tower, but if you're not sure you can find the dimensions of the 770 and measure the inside of your case to make sure you'll have enough room.
Great! Thanks :)
