[SOLVED] Best PSU compatible with 3080 and 10700k
Brownie93
16
I'm about to build a new system and I'm not sure what power supply I should be going for. The hardware I'm going to be putting in is:
Mobo- Asus rog strix z490-E gaming
RAM - G Skill Trident 3200 24gb worth (got a broken stick 😡 )
GPU - RTX 3080
CPU - i7 10700k
I was thinking an 850 W Gold fully modular but was wondering if I'll need more. I'd like to possibly overclock as well.
Thanks in advance :)
A great quality 650W PSU will be enough, but you won't have that much room for overclocking and such. 750W will be plenty for your build.
Some nice choices are:
Corsair: RMx, TXM
EVGA: SuperNova G2, G3
Seasonic: Focus GX/GM
SuperFlower: Leadex II/III
You can also check this PSU tier list:
I wouldn't go below Tier A considering your build.
Corsair: RMx, TXM
