Best PSU For My Build?
Ditto the CXM.
Just a question; why are you using molex for a start?
It's an outdated standard, and all decent fans nowadays should use a 3 pin or 4 pin connector.
Your motherboard also isn't compatible with Kaby Lake unless it was manufactured after said release, which is only about 5% of boards anyway at this stage.
Ok so i changed the mono to a msi b250 and bc the fans in the case are Molex and will the ram work with the mobo?
