[SOLVED] Best PSU for my build?
aryanmirdha10
66
6
4,535
My build is:
AMD Ryzen 7 3700x processor
Gigabyte RTX 2060 Super Gaming OC 8GB graphics card
G.Skill Ripjaws V Series 16GB (8x2) RAM
Asus ROG Strix X570-E Gaming WiFi motherboard
I was planning on buying Corsair RM650X PSU but when i saw the overclocking and increased power consumption of my GPU it makes me wanna get RM750X or even RM850X. Pls help
Good choice on the model. Corsai RMx units are solid.
650W is overkill already looking at your specs.... you'll have a ton of headroom with any amount of overclocking both GPU and CPU.
Even a 550W PSU(great quality) would be enough, but stick to the 650W model if you want to upgrade your GPU/CPU in the future.
Overclocking a 3700x is pointless. Just enable PBO, and leave it alone. That RM650x is plenty, for your system.
Get the black and white RM650W. 650W is spot on.
Thnx ill get the RM650X
