Best quad video card for rampage 4 extreme
aaroon
hi, i have purchased the rampage 4 extreme edition board with the i7 3930k intel chip set, i am looking to run 12 monitors of this setup and was wondering which video card i should use. i have a budget of 200 per card.
What?!
OK so Quad-SLI, but a budget of 200 for each card. Why don't you instead use that $800 for 2x670's? It'll be a bit over 800 but not by a whole lot if you shop wisely.
You're correct but good luck on finding a sub-$200 card that can run a modern game on 3 monitors effectively.
Nothing needs the horsepower of 4 high end graphic cards and in most cases you will bottleneck your CPU by doing so you would need a higher CPU overclock a i5 3570k at 4.8 ghz or something (just guessing) to cope with the amount of gpu power. I'm curious what he's trying to do as well.
your right it is for trading, i bought 2 7750 thinking i could run 4 off each and re-use my one of my older cards
( HIS 5450)to give me a total of 10. so far i have only been able to get 3 monitors working per card 2 dvi and 1 display port to hdmi and the 5450 just sucks power off the board and does nothing. I'm stuck and don't know what to do.
