Best Quiet Videocard for 24" monitor under $150??
Lkdog
Price range is preferably under $150 and under $100 is even better.
I presently have an AGP Nvidia GeForce 7600 GS which is fanless in an older Pentium D 3.4 Ghz system.
It runs at 57-60 C according the Speedfan monitor in normal use.
Will be building a Core 7 system.
Am a casual gamer.
Have a Doublesight 245W 24" monitor.
Would like the best performing quietest and coolest running card for the money in my price range.
The reason I want quiet is that I mostly do audio and music work on my PC.
Thanks for any advice.
einstein4pres
311
Probably something like a 8800GT class with a silent after-market cooler attached. I've heard good things about the accelero S1.
Good choices for the card:
9600gso, 9600gt, 8800gt/9800gt
HD 3850, HD 3870, HD 4830, HD 4850
Of course, to utilize passive cooling, you'll need good case air flow.
r_manic
Administrator
You can also go for the 9500GT. It's basically a budget 8800 and can drive up to 2560x1600 of pixels. Since it's not designed to be the paragon of gaming or anything like that, the stock fan will do.
dirtmountain
Splendid
Apr 19, 2008
3,530
45
I'd go with a GPU that uses an aftermarket type cooler from the factory, MSI has a 9800GT, 9800GT+ and 2 - 4850s that feature this type cooler at or below your budget. 3 pin fan control that can be controlled by Rivatuner for speed/quiet.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127370
If after you've installed and run this card and still find it to be too loud you can replace the shroud/fan with a 120mm low decibel case fan such as a scythe 20db fan for even quieter running (zip tie it in place.)
Lkdog
Thanks for the recommendations! :hello:
Will do some homework and check back when I have more questions.
Am pretty much interested in ones with stock fan/cooling that do the job in terms of heat and noise.
I will probably be using an aftermarket fan/cooler for the CPU, but am not sure if that will be needed
for the Core 7's.
Am using an Alpine cooler/fan on present CPU and it is fantastic and quiet.
