It's great to see someone else who's as excited about this stuff as I am. =) I don't know exactly when I building this rig (within the next 3-4 weeks is my aim) but when I do I will be creating regular build logs for both YouTube and Tom's. =D For now I'm just trying to get the groundwork down and plan as much as I can now so I don't have any delays in the build (I estimate that including testing it will take approximately 5-6 days to complete the build).
Radiator wise I still haven't completely settled on what I want. The case I am going to be using has a stupid amount of possible radiator configurations. =P I'm either going to go with:
1 x 480mm rad (Top)
1 x 360mm rad (Front)
2 x 280mm rad (Basement)
OR
1 x 480mm rad (Top)
1 x 240mm rad (Front)
OR
1 x 480mm rad (Top)
2 x 240mm rad (Basement)
I'm thinking the first option would be best due to the larger radiators, however I don't know if it's possible to fit 280mm rads in the basement. I'm still looking into it. =P Either way I'm going to have plenty of radiators to keep my hardware cool. =) I plan on using the two basement radiators to cool the CPU and the other two to cool the GPU's, but I'm still discussing layouts with someone on another thread:
http://www.tomshardware.co.uk/answers/id-2343645/proposed-watercooling-layout-thoughts.html
I'm not entirely sure what you are on about with regards to having 5 pumps? I will be buying 2 Swiftech MCP 655 pumps, and the Bitspower D5 Mod kit and Mod Top are simply modifications for the pumps themselves?
Swiftech MCP 655 - http://www.frozencpu.com/products/2128/ex-pmp-27/
Bitspower D5 Chrome Pump Mod Kit - http://www.frozencpu.com/products/8803/ex-pmp-80/Bitspower_D5_MCP655_Pump_Mod_Kit_-_Chrome_BP-D5MAV2-SL2.html
Bitspower D5 Extreme Pump Mod Top -
http://www.frozencpu.com/products/12199/ex-pmp-122/Bitspower_D5_MCP655_Extreme_Pump_Mod_Top_V2_-_Acetal_BP-D5TOPP2EX-BK.html#blank
And the XSPC Raystorm is just a CPU block, nothing else:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-069-XS&groupid=962&catid=1519&subcat=2286
The case I'll be using is the Corsair Obsidian Series 900D. A lot of people have mentioned the Magnum to me, and if I was building this rig for anyone else then yeah I'd probably use it, but I personally think it's ugly. It's all out of proportion when compared to a normal case, and I'm not a massive fan of how cube-like it is. Granted it has a massive amount of space, and it certainly is finished in a similar sort of style to the 900D, but the 900D looks like a normal computer case (Aside from it's size of course), and that's what I prefer about it. =/
As soon as I've ordered and recieved all the hardware for the build I'm going to open a build log here on Tom's, so pictures shall be present. ;-) I'll look forward to seeing what you come up with for your build, while I may not like the case I can appreciate it's beauty. =D
I've had another thought with regards to the tubing and fittings. I've seen online that alot of people use clear acrylic tubing with different fittings to compression or barn fittings. I have to say the builds that I have seen utilising acrylic tubing is just the look I'm after, nice straight runs of tubing with no arcing loops of tubing. I need to read into it more because from what I can see using acrylic tubing is harder to set up than standard tubing, but it's looking like this is the way I'm going to go. If you have any advice on this I would love to hear it! =)
Also, if I use acrylic tubing I will end up using coloured coolant instead of coloured tubing. =) How often would you say to purge the system? Yearly? Quarterly? Bi monthly?
If you have any questions please feel free to ask away, I'm sure I've got just as many questions floating around in my head as you have in yours at the minute. XD
Fan wise I'm going to be using all Corsair SP 120/140 quiet edition fans, with the exception of a 140mm AF 140 quiet edition at the rear of the case to help remove the ambient air from inside the case. I think this should be enough as I plan on arranging the fans on the radiators means that there should be a slightly negative air pressure inside the case. As far as fan controlling goes I will be using the ROG Front Panel. It has 5 PWM fan headers, so a number of multi-fan splitters will be needed for all the radiator fans, but I'll make it work. =)
