G Guest Guest Aug 17, 2014 #1 I was considering water cooling my PC but I don't know what length of radiator I need. I see that 1 or 2 sections seem the most common.
damric Illustrious Sep 17, 2010 8,017 73 37,990 Aug 17, 2014 #2 Depnds a lot on which CPU and if you are overclocking. Upvote 0 Downvote
G Guest Guest Aug 17, 2014 #3 Not planning on overclocking because I have the i5 4570. I don't plan on upgrading this CPU until I build another PC with a different loop. Upvote 0 Downvote
damric Illustrious Sep 17, 2010 8,017 73 37,990 Aug 17, 2014 Solution #4 Single 120/140mm radiator will be plenty. Upvote 0 Downvote Solution
