Yeah, I'm leaning more toward the p12s as well. They seem like the best value option with pretty good performance. What speed do you run it at? Also, how are the noise levels?Can vouch for the P12s, replaced one on a 212 plus - much better cooling performance over the sleeve bearing fan. I would like to say it performs better than the EVO model but have not tested / compared directly...
Nice. I think I'll go with the arctics then.Just using the default PWM settings on an old i3-2120 / z68 - a bit overkill but it is absolutely silent, which is great since it's my HTPCSame logic here, got it in the value pack of 5 for $30
