Best replacement for radeon 5450
redtomtom
9
Here is the spec. AMD FX 8320 4.0Ghz 1tb HDD 16gb 1600mhz USB3 ATI 5450 1gb
Whats the best (reasonably affordable) card to replace the 5450
Thanks
Probably better, Aerocool seem to be improving their quality so unless you can find something of similar output at a reasonable price from: Antec, Corsair, Seasonic, Silverstone, XFX or FSP you are good to go.
Exactly which card is a little harder, prices and availability vary hugely but you might be able to source a GTX760 or R9 270X and the upgraded PSU and stay within your $250 budget if you shop around.
Hi
Full spec
Case Built In Vantage Green Gaming Case with LED Fans
Motherboard Gigabyte 78LMT-USB3 Rev 5.0 Black Edition
CPU Type AMD FX Eight Core
CPU Model AMD FX 8320 3.5ghz Eight Core 16mb Cache
CPU Socket AMD AM3 / AM3+
CPU Clock Speed 3.5 Ghz
CPU Max Turbo Speed 4.0 Ghz
Memory 16gb crucial ballistix DDR3 1600mhz Performance Ram
Hard Drive Size 1tb Western Digital WD10EZEX Sata 6Gb/s 64mb Cache 7200rpm
Optical Drive Samsung 24x SH-224DB/BEBE Sata DVD Writer
Graphics Card ATI Radeon 5450 1gb DDR3 with HDMI With Hyper Memory upto 2gb
PSU Size 500 Watt 12cm Fan ATX 12V V2.0 70% Efficiency Power Supply
Operating System Windows 8.1 64bit With License / Disc Installed and Ready to go
Rear Panel Connections 1x DVI Port, 1x Gigabit Lan, 1x HDMI Port, 1x PS/2 Combo Port, 1x VGA Ports, 2x USB 3.0 Ports, 4x USB 2.0 ports, Speaker, Headphone and Mic Ports
Front / Top Case Ports Card Reader, Headphone Jack, Microphone Jack, USB 2.0
Low efficiency means it has to pull more power out of the wall to produce the 500w available to the PC. And it will produce more heat.
A reference 770's tdp is 230w so 20A on the 12v rail is bare minimum. For an overclocked card I'd say 21A or more.
And coozie7 is right, it's better if we know what PSU you have, so we can tell if its good enough or not.
Hi sorry for late reply, there is a time difference.
Yes psu is low I was thinking of replacing it with this
750w atx power supply
+3.3v +5v +12v1 +12v2 -12v +5sb
26a 28a 22a 22a 0.3a 2a
Does that work
Sorry if not providing enough info, I am a real novice at this
Thanks, I am learning, decided that one was a bit suspect and have looked at this instead
AEROCOOL TEMPLARIUS 650W 12V 80+ PLUS SINGLE RAIL 140mm FAN POWER SUPPLY PSU
