Best RX 480 Custom Model Please help!
For an AMD gpu I personally go with sapphire or msi. But I think all will work fine. If you dont plan to overclock go with the one with the highest stock speeds (if the price is not a lot higher). Temperatures and fan noise will be almost identical.
Go with the cheapest one with non reference cooler design. Or if you care about aesthetics, with the one you like most.
