I'm planning to build in a Coolermaster Elite 110 because I want a portable build for lanparties.
The maximum length for a video card to fit in there is 210mm/8.3inch.
Does anyone know a (if possible not terrible) RX480 (8gb) that would fit?
Or should I rather go for the GTX1060 mini?
Otherwhise: Do you know a similarly small or smaller case that has room for some kind of ventilation, at least one HDD and one SSD and a dual slot video card?
EDIT: Just wanted to add that the Sapphire Nitro+ RX480 is 240mm. So if you know any card that's just a little smaller, it could fit.
