Best Ryzen MB for OC'ing and multi display support?
Aug 5, 2018
Best motherboard for Ryzen 2200G/2400G that allows great overclocking featured and supports dual displays?
UPDATED TO ADD:
Therr are some that offer two types of display connections and rumors.of some turning off when the other is used. Just wanting to know if there are any available that offer true dual displays when using the newer AMD APU's.
cin19
Here is our site review: Best AMD Motherboards https://www.tomshardware.com/reviews/best-motherboards,3984-3.html If you want the X470, here is other review: https://www.techspot.com/bestof/amd-x470-motherboards/
In theory you can use the Vega graphics from 2200g/2400g for the dual monitors setup. But if you do something wrong, like use the wrong adapter, cable, and bios setting, then you may have trouble to use the dual monitors setup.
