S SD Phantom Distinguished Jul 28, 2015 62 0 18,630 Jun 15, 2016 #1 I'm wondering what settings I should use for Arma 3. GPU- Gtx 750 ti SC CPU- FX 6300 RAM- 8gb
Solution hang-the-9 Jun 16, 2016 Start at Medium and see how it runs. You are in between the minimum and recommended specs.
hang-the-9 Titan Mar 25, 2010 60,372 1,078 152,940 Jun 16, 2016 Solution #2 Start at Medium and see how it runs. You are in between the minimum and recommended specs. Upvote 0 Downvote Solution
