What did you mean by Best Settings? Best Settings for High Performance or Best Settings for Highest Quality? These two Terms “Quality” and “Performance” are misleading for many people because they mess up these TWO. But here is the real thing – “High Performance” settings will NEVER give you “Highest Quality”, besides this is something which KILLS QUALITY. “High Performance” settings will reduce your in Game Video Quality to run your Game Faster. Besides it will reduce you power consumption as well. But on the other hand settings for “Highest Quality” will give you Stunning Graphics in games providing you Maximum Output of your GPU but also will increase power consumption a bit. Settings for Highest Quality will make your GPU work even harder but this is 100% SAFE as this settings came with manufacturer. As long as you are Not using any Third-party software/tool (MSI After Burner, Asus GPU Tweak, EVGA Precision) to Overclock your GTX 770, YOU HAVE NOTHING TO WORRY ABOUT.
So choice is yours, if you want “High Performance”, just leave the default 3D settings in your control panel which are already optimized as “Performance” mode. But if you are the One chasing after Quality then go for this settings. This Settings are for “HIGHEST QUALITY”. I also got a GTX 770, so believe me this will give you the Best Quality. . Go to manage 3D settings in control panel then choose Global Settings (do not touch program settings). Choose the settings below and Just apply this.
Ambient Occlusion – Quality
Anisotropic Filtering – 16X
Antialiasing FXAA – ON
Antialiasing Gamma Correction – ON
Antialiasing Mode – Override Any Application Setting
Antialiasing Setting – 32X CSAA
Antialiasing Transparency – 8X (supersample)
CUDA GPUs – All
DSR Factors – Don’t Touch it for Playing Newer Games, enabling this High Res Option will consume your V Ram Dramatically. 2 GB V Ram just a NO GO. (BUT YOU ARE THE BOSS, DO WHAT YOU WISH)
Maximum Pre-rendered Frames – 4
Multi-Display/Mixed-GPU Acceleration – Single Display Performance Mode
Power Management Mode – Prefer Maximum Performance
Shader Cache – ON
Texture Filtering Negative LOD Bias – Clamp
Texture Filtering Quality – High Quality
Threaded Optimization – Auto
Triple Buffering – ON
Vertical Sync – ON or Adaptive
Virtual Reality Pre-rendered Frames – (Leave it to 1)
***You will see some options not accessible or dimmed, DON’T WORRY those are linked with others you just set to MAX. This settings will give you Highest Quality Output when you Play Games. You may notice your games are running slow after this settings but you will also notice Fantastic Graphics, yes it should be as now the GPU is working for BEST QUALITY not for best performance. If you see your games are running a bit slow DON’T CHANGE THE SETTING YOU JUST APPLIED ON CONTROL PANEL but change video settings in the Game, MAX OUT EVERY SETTINGS inside any Game but just Turn Off or Reduce ANTIALIASING Settings. A GTX 770 is pretty much enough to handle the rest in MAX. This will give you Superior Video Quality with Nice Performance. If you want to reduce anything do it in the games video settings but make sure your GPU is always ready to provide you its Full Potential through the exact settings I gave you here.
Still Got Something to Know? Ask me here.
GOOD LUCK.
