Question Best SignalRGB compatible rgb controller 4 fan pack for under $60?
Pretty much any fan, that can connect to a motherboard's ARGB/RGB header, is up your alley. Now for your fans, would you want them to double as case and radiator fans or just as case airflow fans?
I suppose just as airflow since I don't have a radiator. So would you recommend a compatible rgb controller and compatible fans?
So, I did some more digging and I found these fans that I want to use.
https://www.amazon.com/Antec-120mm-...keywords=rgb+fans&qid=1649451147&sr=8-10&th=1
I'm not too good with the specs for compatibility, but I have a asrock b450
https://www.newegg.com/asrock-b450m...iption=b450&cm_re=b450-_-13-157-974-_-Product
could you recommend a supported signal rgb rgb controller for this? Thx
