Best silent cooler ever is????
G
Guest
Guest
I'm going mad about my dragon orb 3+ it's too noisy! 38 DB, what is the best solution for my problem? I don't want another cooler as noisy as this one, ARGHHHH!!! Best price is always nice too... Post prices and places to find it if you can!
Thanks, u all...
Well if you live in Canada Ontarioyou get go to bigfootcomputers. They provide awesome fans. the site is www.bigfootcomputers.com. Well i got a new fan for my case 4200rpm. Nice and quite. lol i dunno i you need more power or something but Ummm. For the dragon Orb do u have the 4900rpm or the 7000rpm? http://www.bigfootcomputers.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=Bigfoot&Category_Code=0006 is the site for the top 10 hsf. anyways hope it helps.
\\\//3// 7//3 31337 (0///3 |=0|2 J0/\ 83 |234|)j!!!1
Thanks I'm seeing this site, very good but these air coolers are more noisy than mine, the only one that I think that is ok is the volcano7+ !! My dragon orb is the 7000rpm (38DB) fan! And other problem is to find it here in my country it's way too dificult. I need a fast solution because an friend (Am i lucky or not :) ? ) is going for USA and he can buy an new cooler for me there, he's going in 3 weeks and I'll have to give him the specification plus money to do so!
I live in Brasil and here it's realy hot, my cpu is an tbird1200 but I'm going for an upgrade to an athlonXP1900 plus an abit motherboard kt333 (kt333a if I find), I'm intrested on getting a new cooler that makes less noise and lower my cpu temperature (52idle to 59full load). Do you think that thermaltake volcano7+ is better than my actual cooler? What would be best for me? My case is an IMT4000//Minnions (http://www.colorcases.com/cases/0301.html)... I sawed a lot of coolers, good ones, but some of these do not fit very well on some motherboards too...
Please help me!!
Get a WaterCooler system. For your situation its about the best choice. Goodluck
I want to die like my Grandfather...in my sleep...not screaming in terror like his passengers.
Thanks for your post, but a watercooler is way to expensive, I'm reaching an conlclusion that the best fan is the panasonic ones, they're quiet and works well! For the best heat sink is think that the Thermalright AX-7 wins the prize!! I'm about to ask my friend to bring one of ThermalRight AX-7 w/ Panaflo fan(FBA-08A12H)! Very quiet and works pretty well! I searched a lot of database to reach this conclusion! :)
Link for panaflo fans (the site is very nice u can see the maxairflow+noise+rpm of their fans):
http://www.panasonic.com/industrial/appliance/appliance_fans_panaflo_axial.htm
actaul see if the alpha 8045 will fit on you morther baord. then just put a pnfol fan on it
what is better then a 7000 rpm, a 8000 rpm delta. to cause more noise to kill your ears :smile:
Thanks a lot for your post this alfa that you told me seems to be very good! I looked at it's score at www.overclockers.com seems pretty nice!!!! This is another candidate for me! I was wandering, what is the price for an watercooler, don't need to be a top one, an average an quiet one! Where inside inernet I can find watercoolers kit ready to use? Whith the pump, radiator, waterblock and these small tubes, all of it? Is it expencive?
I found one site in my coutry (http://www.watercool.hpg.ig.com.br/index.htm) but I think that this watercoolers that they have is low quality, pls check this site and see if you agree whith me!!!
DIY all I bought was a pump, tubing, waterblock and a couple of plastic storage boxes, details <A HREF="http://www.calvsplace.cwc.net" target="_new">here</A> didnt cost much at all.
If they squeeze olives to get olive oil, how do they get baby oil?
