I will be buying a HDTV and using it as a PC monitor as it seems to be the best value for the biggest screen. I am torn between a Bush 32" and a 27".
My question is this; both tvs run at the same resolution 1366 by 768 or thereabouts, so which would look better as a pc monitor, would the 32" be too big for that resolution, or would the icons on the 27 inch be too small?
Is there a particular HDTV size that is best for use as a PC monitor
