Best small CPU cooler?
bnot
708
4
Hello,
I am running a Core i3 540 and normal RAM (i.e. not high, no heat spreaders or anything). I need a better CPU cooler than the stock so I can overclock a bit. My case is the QoRi M103-A11. It has this strange tube/funnel apparatus over the CPU cooler, and I think it's supposed to direct airflow.
So, I need a good CPU cooler for overclocking that fits LGA1156, is relatively short, and is easy to install without removing the motherboard.
Thanks in advance!
socialfox
2,652
149
You should be able to remove the funnel by removing the screws securing it to the side panel. I would recommend the Cooler Master Hyper TX-3 for an effective CPU cooler that's small and does not need to have a back-plate installed. Also could you give me a link to your computer case, I can't seem to find a page in english. I guess its by some small company?
socialfox
2,652
149
Can you measure the distance from the retention clips to the funnel? While I will be looking up for some small CPU coolers, think you may have to go old school and get the coolers that sit on the CPU completely and have a fan that lines up with the funnel and draws air from it.
Update: Compatible coolers with your case that can be the Noctua NH-L12 (high end low profile cooler) and the Zalman CNPS8900 Extreme however I do not know any Intel coolers that are low profile and mount without a backplate, these coolers use backplates. Installing a back plate is not as hard as it seems.
naama
53
I own the noctua nh-l12. I've been satisfied with it. It cools my 3570k very nicely. Even at 4.2 ghz.
http://www.silentpcreview.com/Noctua_NH-L12
naama
53
Yes, at least for my socket 1155 mobo it required a backplate. It was easy installing it.
bnot
708
4
Thanks guys, I think I'll go with the Noctua. It turns out that the funnel might be removable, but it might not even get in the way. If it does, I can remove the top fan.
As for the backplate, I might be in luck, as both side panels are removable. Therefore, I have easy access to the back of the mobo without removing it.
Similar threads
