So my ISP provided me with a bad router that has bad signal. The router sits in the living room, and that's pretty much the only place the WiFi signal is strong enough. When I go to the other rooms, which aren't too far, the signal drops to zero, i.e no internet. Maybe the thick walls are to blame too.
I was thinking about a few solutions and I'd like you to tell me which one do you think is the best:
1) Buy a set of repeaters and spread them across the house - put a repeater in the middle way between the router and the rooms, and more repeaters inside the room - But I have no idea if repeaters actually work.. and the fact that the walls are thick - will it even work?
2) Buy a powerline kit with WiFi like this one: Powerline 600 Wi-Fi 3-pack Kit - Looks like a decent solution
3) Since the kit above may be hard to get in my country, I was thinking about getting a regular set of powerline adapters, and to each powerline (in each separate room) connect an AP or a router that will act as an AP - The problem here is that each room is going to have his own different WiFi network, which is annoying because whenever I switch between rooms I have to log into a different WiFi network to get the best signal. But, maybe you know of a smart AP/router that can actually turn this WiFi network into a seamless single network that would switch automatically between the networks whenever I am going near the closest AP/router? Something like the kit above, just using AP/router instead of a ready kit (Because the kit above may not be available to me)
Thanks!
Thanks!
