Ive got a ml120l and im looking to replace the fans that are very loud when under load. Any recommendations for static pressure fans that have rgb or red led that are not too loud?
what aio do you have?i dont know about RGB or LED fans, but i replaced mine ml120 with Arctics P120 PWM and it really works good. The cooler temp difference -5c and CPU from 86c to 77c after 1 or 2 gaming hours (Shadow of the Tomb Raider, Call of Duty MW, Control).
The best thing is, i keep the iCue setting performance on Balance, fans stays 1500-1900rpm without noise.
If you could try some not led fans, i recommend this.
you get 77c when gaming damn you must have a hot chipCorsair iCue H100i RGB Pro XT
thank you for the help and funny enough i have those exact fans coming todayCorsair iCue H100i RGB Pro XT
