Best Storage Solution
Leoderas
Commendable
May 19, 2016
14
Hey im looking for the best storage solution for my budget gaming rig , i have an old 500gb 5400rpm laptop hard drive, here's the problem there's two paths i can choose first one is buying a cheap SSD for os and some core programs and using my 500gb laptop hard drive for storage, or the second path that's buying a new 1TB 7200 rpm hard drive, Which configuration will work more effectively ? any other suggestions are well received, my hard drive budget is around $65 usd dollars.
Here's a list of of the parts im taking in consideration:
SSD:
MyDigitalSSD 240GB (256GB) BP5e Slim 7 Series 7mm 2.5" SATA III (6G) SSD Solid State Drive - MDS7-BP5e-0256G
Looks like a speedy budget ssd with a good amount of storage, im a bit concerned about quality tho.(im adding amazon links for in depth product specifications)
http://www.amazon.com/MyDigitalSSD-240GB-256GB-Solid-State/dp/B01974UGNA/ref=redir_mobile_desktop?ie=UTF8&ref_=cm_cr_arp_mb_bdcrb_top
Mechanical Drive:
Western Digital 1TB SATA 7200 Rpm 64MB 3.5in 6GB/S, Color Caviar Blue
This one looks like a solid pick for a mechanical Hard drive.
http://www.amazon.com/Western-Digital-3-5in-Color-Caviar/dp/B0088PUEPK?ie=UTF8&keywords=hard%20drives&qid=1464312889&ref_=sr_1_1&sr=8-1
Thats preatty much all info regarding my disk choices, if you can suggest me any better ssd alternative within my budget limit please let me know, i really want to try the ssd extra speed, could also upgrade the 500gb hard drive later on, but i looking for the best posible solution right now.
Here's my current build
CPU: Intel i5 6600 (nonk)
Cooler: Stock one
Motherboard: Asus H170 pro graming
Ram: Kingston HyperX (2x4GB)
GPU: in progress (gtx 750 ti or a gtx 950)
PSU: cheap one 500w
I would definitely choose to go with an SSD now, and upgrade the HDD later if need be. I also wouldn't go with the unit you've outlined. This is a better unit.
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive ($59.99 @ Amazon)
Total: $59.99
Generated by PCPartPicker 2016-05-26 23:49 EDT-0400
This is another option, using a hybrid drive with platter storage but using SSD Nand cache.
Storage: Seagate 1TB 3.5" 7200RPM Hybrid Internal Hard Drive ($64.99 @ Newegg)
Total: $64.99...
Total: $59.99
Total: $64.99
Generated by PCPartPicker 2016-05-26 23:51 EDT-0400
Personally, I'd be more worried about replacing the cheap power supply than I would the storage drive, unless your storage drive is more than five years old or is exhibiting problems, in which case, reusing it shouldn't even be considered an option anyhow.
Thanks for the suggestions!
I'll go with the
Looks very reliable and has good reviews.
Also im going to buy this PSU, is it good enough for my build?
EVGA 430W 80+ Certified ATX Power Supply
http://pcpartpicker.com/part/evga-power-supply-100w10430kr
Here's how my build is going:
http://pcpartpicker.com/p/NV8j4C
Cooler: Stock one
PSU: EVGA 430W 80+ Certified ATX Power Supply
And actually, that unit is on sale right now with an additional ten dollar rebate, bringing it's total after rebate to 49.99 if you can buy from Newegg.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820228142&utm_medium=Email&utm_source=IGNEFL052716&cm_mmc=EMC-IGNEFL052716-_-EMC-052716-Index-_-InternalSSDs-_-20228142-S0A
Honestly, while I normally would choose most of the EVGA models over Corsair units, in this case, this might be the better option as those W1 EVGA units are not honestly very great. In a pinch, it will certainly be a major improvement over any no-name off brand unit though, so if that's what you have, then either this unit below or the one you linked to is certainly recommended over that.
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($45.99 @ Amazon)
Total: $45.99
Generated by PCPartPicker 2016-05-27 12:11 EDT-0400
