[SOLVED] Best suited monitor?
aLp!n3
22
This is my configuration
Processor - Intel i3-8100 3.60GHz
RAM - 8GB GSkill Ripjaws DDR4
Graphics Card - Nvidia GeForce GTX 1050Ti 4GB GDDR5
Motherboard - MSI B360M PRO-VD
So I kinda wanna play games like Control, Cyberpunk, Red Dead Redemption and so on (No online games except FIFA) so I wanted to know which monitor would be the BEST. As in, a monitor that just has the right features (not too high, that my card can't achieve and not too low either)
Alright... Do you have something in mind?
The 1050ti will not manage 144fps in most games. CSGO etc might just about reach it but like mentioned, a monitor at 1080p will be fine. It can be a curved fancy one but it only depends on your budget. Also how much fps are you comfortable with? Because if you are thinking of playing Cyberpunk 2077 and red dead then a 1050ti will struggle to pull to 40fps on the lowest if you mean 2077 and rdr2.
Reactions: aLp!n3
I agree, the 1050Ti will not be able to achieve 1080p144Hz for most games apart from CSGO, Rocket League, maybe Fortnite on low.
You could get a 144Hz monitor for convenience as it's still a luxury to have such a high refresh rate monitor. Even for just everyday browsing. Specially if you will upgrade your GPU in the future. Just be ready to regularly switch between 60/144Hz.
It would be nice to have a budget to work with, but here are some 75Hz suggestions:
https://pcpartpicker.com/product/j2smP6/aoc-24v2h-238-1920x1080-75-hz-monitor-24v2h
https://pcpartpicker.com/product/94...20rn-236-1920x1080-75-hz-monitor-c248w-1920rn
And some 144Hz options:
https://pcpartpicker.com/product/HBRzK8/aoc-c24g1-240-1920x1080-144-hz-monitor-c24g1
Feel free to just go on https://pcpartpicker.com and find the model that suits you.
Reactions: aLp!n3
Oh
Oh I see 🙁 I don't think I'll be upgrading my GPU any soon but yeah, in the future I surely will though.
What are your thoughts on this one
LG Ultragear 24" 144Hz, Native 1ms Full HD Gaming Monitor with Radeon Freesync - 24GL600 https://www.amazon.in/dp/B07S146CB6/ref=cm_sw_r_cp_apa_i_wzJxEbBRE22T5
Oh
Like mentioned, really not worth getting a 144hz monitor however. Yeah it is cool and smooth when browsing but generally you will find it stupid having such a low-tier card for a monitor like this if you cant even reach 60fps on those games. Do you have a monitor now, what are its specs. If you have a decent monitor, use the money to buy a new card such as a rx580 for cheap and if you have one, a good psu. How come you can't upgrade your GPU?
Okay.. It seems reasonable. I have pretty basic monitor and that's https://www.cnet.com/products/dell-e1914h-led-monitor-19-series/
and I have a Corsair VS450 PSU. So what should I do? A monitor or another GPU (if so then which one? Budget being aroumg 18,000INR)
Your montior is pretty standard and you don't need an upgrade. Your psu is pretty bad against most gpu's. I would buy a better gpu but also a better psu for pretty cheap (maybe 550 - 650W, the CX psu's are decent and cheap). Do you also have access to buy a new psu as well with a card?
Sure. I think I can get a 550W PSU
