Best supported GPU for ASRock Z87 Pro4
Jan 16, 2019
I have a i7 4770 processor with ASRock z87 Pro4 and gtx 950. I want to upgrade the GPU. I don't know anything about configurations. Can anyone suggest me top most supported GPU for my CPU(i7 4770) and motherboard(ASRock z87 Pro4)?
1060 6GB or RX 580 are good options for 1080p high settings gaming.
If you want to play at max settings and/or be able to handle games a little further into the future, you could stretch to a 1070 or vega 56.
Any card all the way up to a 2080 Ti is compatible, assuming your power supply is up to the task. There will likely be some CPU bottleneck depending on how powerful a card you get though.
What resolution and refresh rate is your monitor? What exact model of power supply do you have?
I've 24 inch Full HD LED monitor. (60 hz refresh rate I think) and 600 watt power supply.
As per my budget, I can afford 1060 (3 gb or 6gb) or at most 1070, so which one do you suggest?
My requirement is to play all AAA games without any lag at 1080p.
