Best Thermal Performance case for matx build?
Jan 17, 2019
8
My pc case literally has no fans, and there are only holes at the side panel and the back.
When gpu runs hot whenever i play games like apex legends or r6 WITH SIDE PANEL ON.
But when i play without side panel, it really made a huge difference, my gpu never peak at 65 degree celsius.So i really need to know whats the best case for matx build without hurting my wallet.
Ambient Temperature is 27 btw
im not really into cube cases but meshify c mini seems dope! How well is the thermal performance? and also any other suggestion?
There is a number of cases that compete for that title. Imo, find one that suits your budget and has ample openings for a good airflow, and then throw in a couple of good fans.
i ll look at q300l from cooler master then i decide
q300l seems like a cheaper version but i ll look into reviews then i ll decide
