Best turntable for wireless Bose speakers
Cluelessbird
Hello. I need help please! Any recommendations for the best turntable to go with the above?
I'm buying the turntable as a gift.
Bose Model number would be helpful.
You will need a turntable with a built in phono preamp. If the speakers have an aux analog audio input you would need an adapter with 2 female RCA at one end (for the TT) and a male 3.5mm stereo plug on the other (for the Bose).
If not you would need a bluetooth transmitter to connect to the TT.
There are a wide choice ot turntables and most of the cheaper ones have the phone preamp built in.
http://www.amazon.com/Technica-AT-LP60-Automatic-Stereo-Turntable/dp/B002GYTPAE
http://www.crutchfield.com/p_033DP29F/Denon-DP-29F.html?tp=200&awkw=75735934225&awat=pla_with_promotion&awnw=g&awcr=48387075625&awdv=c
