Question Best Unigine Heaven and p95 settings for GPU and CPU?
Theminecraftaddict555
652
I'm having a hardware issue and wondering if its related to the GPU or CPU and wondering what settings I should use for my 5800x CPU and 5700xt 8GB GPU. Is the defaults fine or do I need to do some tuning?
If you just want to stress them to see where the problem is, I don't think it matters too much.
I would always start with memtestx86 to rule out the easily replaceable system memory.
Crashing under load can also be power related, so make sure your PSU is putting out proper voltages under load.
Just ran it for 7-8 hours. No issue for p95. Now will run unigine on GPU
Just stress tested GPU for 6-7 hours. no issues. I already memtested 6-8 hours too, no errors. Anyway to stress test the PSU, unless the gpu tests already determine that?
