Best upgrade for my current build
Nov 15, 2018
16
Here’s my current build:
CPU: i5-3470
GPU: GTX 960 2GB
RAM: 8GBDDR3
Mobo:H61M-E
PSU: 600w
Just wanted to know which of these I can upgrade to increase my PC’s performance especially when gaming. I’m usually play DOTA2 and CS:GO.
My budget is about PHP 18,000 (around 340USD) and I live in the Philippines. My initial plan was is to upgrade my mobo, CPU to i5-8400, and get DDR4 8GB RAM
Any ideas guys? All will be appreciated. Just wanted to know which upgraded will be the best considering my budget. Thanks.
you will need new motherboard for that, like 3xx series. I will say the system is well balanced with dota and csgo. Just save more and change to 8th/9th Intel or Ryzen in the future.
Already upgraded my motherboard and CPU to i5-8400. Will get a decent GPU as soon as I have enough budget. Thanks a lot :)
