Question Best vBios for RTX 3090 Trinity OC, and figures for overclocking it ?
warriorlax1234
46
Hello Everyone,
Since I'm an impatient person, I went ahead and bought an RTX 3090 to upgrade from an RTX 2080. Performance is incredible. Who needs a 4000 series anyway?
Any who... I'm an avid over clocker. I've never had a challenge overclocking my system top to bottom but this Zotac Trinity OC RTX 3090 is a tricky one.
Since I've read that this specific model locks the power limit (might be correctable via Zotac provided vbios update for resizable bar - "maybe" or so I've read) I'm not sure what option to take here. I'm not one for taking huge risks, so I'm a little worried about flashing an off brand (such as MSI) vbios incase it bricks my card. However, if my only option to really overclock is to use an off brand vbios, I can do that if I find the courage.
Questions are these...
(1) If you were in my position, important to squeeze every single FPS out of the system, should I upgrade the Vbios to an off brand and see how that works? Is the risk mitigated knowing I have an Intel CPU K series that has video and so does my mobo? Or in other words, I update the vbios, brick the card, plug into my mobo hdmi for video, then flash the card again in hopes it fixes the brick? Is that one way to revert an potential issue?
(2) Or download the Zotac vbios for resizable bar, hoping that unlocks the power limit and can therefor push the card higher?
Depending on the answer for the first two questions...
(3) What numbers are you currently using? I have curve set (via afterburner) by the overclocking tool, and memory I set for +1200. Ran all benchmark tests and gaming, not a single crash. I'm not trying to break 3dmark speed records here, just want to unlock the full potential of the card.
Your feedback is greatly appreciated
I was able to overclock it quite a bit. +90 on core , 1200 on mem. Stable. Increased voltage to +110.
+90 base isnt really much tbh
try with curve editor in afterburner, find your best clock per each voltage step
having power limited board, you might find better clock at lower voltages (to stay within power limit) gpu freqency will be pretty much throttled all the time so it would be lowering voltages to stay within tdp, and having more frequency at lower voltages would mean gpu wouldnt fluctuate that much and will produce less heat at higher clocks
Reactions: Phaaze88
