Best VGA cooler for 5700 and 5800 series?
yiplong
116
I have a HD 5750 and a 5850 video card, the fans on both cards sound like tornado when I play any kind of video game. Such noise level is utterly unacceptable to me. Any good VGA coolers that work with these cards? I would like the coolers to have these attributes:
- fit the cards, of course
- low noise
- cost less than $50
- cools the chips better than stock cooler
I think these are very reasonable things to require of any aftermarket cooler. Thanks for any suggestion!
builderbobftw
Splendid
Feb 6, 2010
3,601
14
Meh, the stock one will do all that.( Except cool better than stock,lol)
If they are that loud, amybe something is wrong wit the fan??
yiplong
116
I think the fans are fine, they are just loud. Loud noise is common with video card fans.
yiplong
116
40% fan speed will cause the cards to overheat during intense gaming. Both cards are OCed to the max.
builderbobftw
Splendid
Feb 6, 2010
3,601
14
Oh, well ok. I have my stocks at 40% at they do just fine during Crysis, cuase they are at stock. Well you can't expect to OC and get low noise at the same time, not gonna happen.
vvhocare5
769
32
Hi yiplong
There is no cooler on the market yet for these cards. It takes the makers of these things almost a year to build a replacement cooler.
I know what you mean about noise from these things - I have 2 5850's and since I overclock them they heat up quickly. I have to run the fans at 75% to keep the temp at 80C. Talk about a vacuum cleaner next to your ears...
It wont help much but replacing the thermal compound looks to be good for a couple of degrees of cooling - maybe 5.
Also making sure your case has very good airflow helps a little too.
But until anything better comes along we play games with headphones on
Similar threads
