Nonscrub Reputable Jan 26, 2016 137 0 4,680 May 26, 2016 #1 What is the best water cooler for an i5 6600K which I do plan to overclock?
Solution Gam3r01 Jun 6, 2016 I said open loop, not custom. Something like the EKWB Predator series, Swiftech H240x2, etc.
superninja12 Glorious May 18, 2015 11,378 56 49,140 May 26, 2016 #2 kraken x61 however i would get a hybrid cooler the cryorig h40/h40 ultimate/h80 Upvote 0 Downvote
Nonscrub Reputable Jan 26, 2016 137 0 4,680 May 26, 2016 #3 superninja12 : kraken x61 however i would get a hybrid cooler the cryorig h40/h40 ultimate/h80 They haven't even been released yet. Upvote 0 Downvote
Nonscrub Reputable Jan 26, 2016 137 0 4,680 Jun 3, 2016 #5 superninja12 : yes they are? link? Upvote 0 Downvote
M mir_1 Reputable Sep 16, 2015 28 0 4,530 Jun 3, 2016 #6 What about arctic liquid 120? Upvote 0 Downvote
superninja12 Glorious May 18, 2015 11,378 56 49,140 Jun 3, 2016 #7 http://www.cryorig.com/a-series.php Upvote 0 Downvote
Nonscrub Reputable Jan 26, 2016 137 0 4,680 Jun 6, 2016 #8 superninja12 : http://www.cryorig.com/a-series.php Which one should I get Upvote 0 Downvote
superninja12 Glorious May 18, 2015 11,378 56 49,140 Jun 6, 2016 #9 depends on your case. Upvote 0 Downvote
Gam3r01 Titan Jan 12, 2013 25,412 973 115,440 Jun 6, 2016 #10 What are your full specs including budget? AIO coolers are a waste, you should get an open loop cooler (if budget and case allow) Upvote 0 Downvote
Nonscrub Reputable Jan 26, 2016 137 0 4,680 Jun 6, 2016 #11 Gam3r01 : What are your full specs including budget? AIO coolers are a waste, you should get an open loop cooler (if budget and case allow) Probably not going to build one or spend money on one. Upvote 0 Downvote
Gam3r01 Titan Jan 12, 2013 25,412 973 115,440 Jun 6, 2016 Solution #12 I said open loop, not custom. Something like the EKWB Predator series, Swiftech H240x2, etc. Upvote 0 Downvote Solution
