Best Water Cooling Kit
HatebreederGaby
Hello everyone, i'm one click away to ordering my components for my new PC but i just cant get decided on the cooling system. I like the specs on the Cooler Master Nepton 140XL mounted on the back of my case, tho i will get a i7 with a GTX 780ti and things might get really hot after overclocking, so maybe a larger Radiator might be better, but then, i'm going with the Obsidian 650d for my case and it seems a bit small for a giant Radiator on top. It says that the case can have a 240mm or a 280mm Radiator and the best i found was the CORSAIR Hydro Series H100i Extreme Performance. Is this the top of the food chain for Water Cooling? I have no money limit and i just want the best of the best for water cooling, Please feel free to give any advice what so ever, that's why i'm asking!
Thanks.
You are at the typical threshold of making a major purchasing mistake then seriously regretting it later because overclocking does bring serious heat just as you said, so pull back the reins on that stage coach and slow down that purchasing decision until you have enough information to proceed.
The biggest problem new radiator water coolers make is not having enough radiator cooling field to handle the overclocked components heat output!
It is interesting that you're already considering a rear or top mount you're better off than most right there that limit themselves trying to cram it all inside a case, of course unless it's a Mountain Mods Cube case, with plenty of room inside of it.
They usually let the case mounting limitations dictate the cooling solution they end up buying, so have you already committed yourself or not?
