Hi there, I was wondering what the best closed loop water cooler would be for my Intel Core i5-4670K. It has to fit into a NZXT PHANTOM 630.
Thanks, Lawson!
Currently using TT 3.0 Water Performer with 4670K http://i57.tinypic.com/2diq8pi.png
here are the results with prime95 ran it for 60mins ....
had installed 2x120mm fans............
NZXT Kraken X60. It has an advantage over the Corsair closed loop liquid coolers because it uses 2 140mm fans, making it a 280mm radiator, instead of Corsair's dual 120mm fans, or 240mm radiator.
Thanks, Lawson!
