G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
I recently stripped a TZ playfield and used the Treasure Cove
polishing products on it to shine it up (which worked well btw). Now
I want to wax it and I've done some googling and can't get a good
answer on what to use. I don't necessarily care about brand, but do
most people use pastes or liquid on a playfield? Is there any
difference? And do people recommend caranuba waxes, synthetic waxes,
or does it matter? Can I use the same Meguires Gold that I use on my
car (which says it contains petroleum distallates on the bottle but is
safe for clearcoat finishes), or do I need something gentler for
pinball? Or something harder? And I don't need a cleaner/wax combo
like millwax since I've already cleaned the heck out of it. I'm sure
there will be a lot of dissenting opinions on this, but what do you
use??? Thanks,
use??? Thanks,
