Question Best way to connect a HDMI monitor to a DP output?
tom2u
295
I've got an old motherboard with built on video with DP and VGA outputs. My 27" 1920 x 1080 monitor just has HDMI input. So I could use
1: DP to HDMI cable (seems to be the most expensive because its the least popular configuration)
2: DP to HDMI adapter and HDMI to HDMI cable.
3: DP to DVI adapter and DVI to HDMI cable (already have the DVI TO HDMI cable but its too short).
Is it ever a problem going from DP to DVI to HDMI?
Are there different types of DP to HDMI adapters? Should I be worried about compatibility? I thought I read something about this before in an article cautioning about cheap adapters yet some people seem to use them with good results. Not sure if it makes a difference if the output is coming from a video card or motherboard. I'm using an old Intel 1155 based Lenovo IS6SM motherboard with DDR3 ram and a i5 2400 CPU.
All 3 are equivalent, use whichever is convenient. Adapter dongles are preferred over adapter cables because you can attach a different length cable in the future if your setup changes.
Yes, see here: https://linustechtips.com/main/topic/729232-guide-to-display-cables-adapters-v2/?output=DP&input=HDMI
No, the only difference is limited capability between different adapters.
