[SOLVED] Best way to expand my WiFi signal
shaun88
279
I’d like to know the best way to expand my WiFi signal, my sky modem is downstairs in my living room, but upstairs in my bedroom, which is above my living room but on the other side of the house, WiFi signal is weak and sometimes cuts out. I’ve looked at WiFi extenders/boosters but I’ve read that I’d need to go into my iPhone WiFi settings, or laptop WiFi connections to select the expanded/booster, I don’t want to do this every time I go upstairs, I’d just like strong WiFi all around
Many thanks
Seamless roaming between WIFI signals does not work well with home WIFI. You could try a mesh system like the Netgear Orbi. But manually selecting the best WIFI source is still the most reliable.
