M MisterJones Prominent Jul 26, 2017 2 0 510 Jul 26, 2017 #1 Used the air can, but there's still a coat of dust caked on in some areas. What's the best way to deal with this?
C chalky16 Reputable Jan 4, 2016 375 0 4,860 Jul 26, 2017 #2 You could use an air compressor but it may damage stuff inside. But don't use a vacuum because it can have static energy, also don't go inside and try to clean it out. Upvote 0 Downvote
M MisterJones Prominent Jul 26, 2017 2 0 510 Jul 26, 2017 #3 Pretty worried about using an air compressor. Any brushes an option? Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 177,380 20,793 184,590 Jul 26, 2017 #4 More canned air. You're not getting close enough to the caked on bits. Upvote 0 Downvote
