G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I don't understand why ATI doesn't make AIW cards that support dual monitor
setup... Most AIW cards only support one monitor.
To get DVI flat panel + VGA CRT monitor + VIVO/TV in one system, which one
of the following plan is better?
1), Standard Radeon 9000 pro card (provides dual DVI & VGA connector) + TV
wonder Pro
2) AIW 9000 pro (one DVI connector, but with build-in TV tuner & video
capture) + second video card in PCI slot
In terms of performance, price and ease of implementation, which solution is
better?
Will there be a conflict if two set of drivers are loaded for two graphic
cards in one system?
wonder Pro
better?
