Question Best way to get fans working with Mystic Lights or Synapse?
Oct 6, 2021
First off thanks for your time and second I apologize of my lack of knowledge of this RGB LED stuff. Here is my issue. I just bought a new motherboard, case, and fans and would like to have them all controlled by some sort of software and sync them all up with games and what not. Right now I have the six smaller ones plugged into a hub that came with them. The hub doesn't plug into the motherboard though. So I can only use the remote that was included to change the lights. The three larger fans are still in route and I haven't got them yet and am starting to wonder how they will plug in at all.
I have this motherboard...
MSI B550 Gaming Plus
https://www.bestbuy.com/site/msi-b550-gaming-plus-socket-am4-usb-c-gen-2-amd-atx-gaming-motherboard-pcie-gen-4-black/6424047.p?skuId=6424047
with these fans...
6 - 120mm 4pin RGB Fans
https://www.newegg.com/p/1YF-018M-00026?Item=9SIAP6DDAZ0920
and
3 - 140mm 6pin RGB Fans
https://www.newegg.com/p/1YF-01CZ-00002?Item=9SIAZ88EUY7038
What would be my best option to get them all working in sync with something like MSI Mystic Lights controls or Razer Synapse? I assume I will need to buy a hub of some sort?
Thanks again!
MagnusKain
to sync all of your 4 pin RGB devices you would need an LED hub that offers enough connections for all of the devices and has a 4 pin out that will run to a motherboard header.
the 140mm fans use a proprietary 6 pin connection that will not work unless you also have one of their proprietary controllers to connect to.
you should return those and get something better that uses standard connections.
