G
Guest
Guest
I'm about the build my first PC in about a week or so and I wanted to take extra precautions on ESD. (Better safe than sorry). Using a Anti-Static Wristband, what would be the most optimal way to stop from shorting out my components? Also, should I clip the band to the case of my old PC and plug in the power supply without turning it on? Or should I just clip it on the case w/o plugging the power supply? Or any suggestions? I am using a Corsair Carbide 200R which is all painted so that's why I'm clipping it to my old PC. (I'm working on carpet if that helps). Thanks.
