G
Guest
Guest
Hello!
So I bought MSI R9 290 Gaming some time ago, it's quieter than reference R9 but still not quiet enough, so before I'll change the cooler to something better first I want to try to improve air circulation instead. So, below Is shown how it looks now (case's Silencio 352).
So, I think of buying 2 x 120mm fans for intake (front) and a 140mm exhaust fan. What do you guys think? I don't know what fans should I get although Aerocool Dead Silence look interesting.
Important notes:
1. The PC is in specific position so it has only 10 cm distance to shelf (on the top) and about 7cm to the wall (on the rear).
2. I have dismounted the bottom disk cage so it doesn't obstruc airflow.
3. I have the intake mounted on the bottom of the front (on picture is on the top of the front).
Important notes:
