Best way to improve signal ?
G
Guest
Guest
Archived from groups: alt.internet.wireless (More info?)
I am about to install a linksys wrt54g router and try and use it about
100 ft away in the garden through several brick walls.
i dont think i stand a chance.
how can i boost the signal ?
should i buy an external antenna or a repeater or another access point
any help appreciated,
G
Guest
Guest
<sam1967@hetnet.nl> wrote in message
news:99s2g05ti96ihl2brktrsqe2fu9bde0e30@4ax.com...
External antennas will be your best bet. Directional would be best. There
are even plans for home built ones on the internet.
AG
G
Guest
Guest
The brick walls might present a problem.
You can start with simple reflectors.
http://www.freeantennas.com EZ10, or the original parabolic.
That's free, and easy to try.
Postion the wrt54g near a window, even if it isn't line of site.
External antennas could be mounted outside the brick walls. Homebuilt
patch antennas are moderately directional, but more important is that they
are cheap, and can be placed fairly inconspicuously outside the brick
walls.
http://www.geocities.com/lincomatic/wifipatchantenna.html
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8-122.5
G
Guest
Guest
On Fri, 23 Jul 2004 21:45:03 +0000 (UTC),
thanks,
anyone in the UK wish to sell me one of these parabolic antennaes ??
G
Guest
Guest
I consider David Taylor's web page to be good reading, and contains some
specific recommendations for the UK.
< http://www.nodomainname.co.uk/cantenna/cantenna.htm >
G
Guest
Guest
On Sat, 24 Jul 2004 17:52:40 +0000 (UTC),
thanks for the link. nice to get some local knowledge too.
