Question Best way to make a clean install drive
Raena92
Commendable
May 4, 2019
21
I do have a question, but want to leave a kudo first: I've posted to this forum before, and got help for my problem, ie: a question about wifi, and I was having problems with an almost new XPS 8930. Someone here said it sounded like the OS had been installed on the HDD, as opposed to the SSD. Sure enough; that was it. I sent the tower back to Dell; they admitted the OS had been incorrectly installed -- and when I got the tower back, there was an improvement. But, not a complete fix, in my opinion. Then again, who am I?
Recently, the computer just stopped working. Not a very good description, but that's all I can say. After loving Dell for years, I was so disgusted. But, since the computer was still under the Support Premium Plus plan, Dell sent a certified on-site technician. He replaced the SSD, the motherboard, and a couple other things. Then, he said, "Well, you basically have a brand new computer again."
That's good, and I want to keep it in good order, So here's my question: Can I move or install or copy my entire C Drive (which is now on the SSD) to a USB drive, and make that work for a clean install if necessary?
If so, how do I set the BIOS to boot from the USB.
I've done this with every computer I've had, and it has saved my butt a couple of times. Now, maybe because of the problems I've had with the XPS, I'm afraid to do much of anything without advice from those who know more than I do. Thanks so much.
Raena92
Commendable
May 4, 2019
21
Thank you so much, Jay! Now, I have another question: I've heard of cloning software, but don't now what it is. Could you tell me where to get such a thing? Hopefully, it can be downloaded from the internet.
Also, if I would need to use an image of the drive for a clean install, don't I have to set something in the BIOS, so the computer will boot from the USB? Thanks again.
jay32267
Champion
I use Aomei Backupper. It's free.
Many people use Macrium Reflect. It's also free.
Being you just got the PC repaired and I assume it's working correctly....now would be a great time to make the image.
If you make an image....and need to use it.....you would have to boot from something besides your OS drive.....and usually this would be a USB stick (in my world)......and you would set it to boot from the USB in the BIOS.
USAFRet
147,451
9,350
175,390
23,026
Not a full clone, but rather an Image.
Macrium Reflect.
For all of my systems, I have a Day 1 and Day 2 image.
Day 1 = the bare OS with whatever updates are happening.
Day 2 = The same system with my basic load of applications.
And Image in Macrium lets you store multiple images on a single drive. And use the rest of the drive for whatever you wish.
Also in Macrium, you create a REscue USB.
If you ever need to recover that Image, you boot from the RescueUSB, and tell it what Image and which drive to apply it to.
After that, I also do a rolling series of Incremental or Differential images.
