Hey guys, I'm really paranoid about overheating my new gaming pc that I just built. I had at least 4 laptops/computer in the past and they all died due to overheating. So I figured I invest in a gaming pc that will perform on higher end games that I play.
My specs are:
- Thermalake aserIII super tower
- A10-6800K Processor, AMD HD8670D inegrated graphics
- Asrock fm2a75-itx
- 120gb seagate 7200rpm hdd
- Corshair gs800 Power supply
I'm not serious in needing high-end graphic/visual desires, I rather playing on the lowest settings. More gameplay critic than visual. The Case itself has 7 80mm fans, with the corshair power supply fan, and of course a stock cpu fan. The fan covers every 3 dimensional section of the case except the bottom and the air current blows inward with the exception of one fan blowing outward. I only keep the computer on for at the most 4 hours a day. Also its station next to my ac unit. Is this good enough to keep it from overheating? the case is made of aluminum if that matters.
Also, my case has a temperature reading LED and it stays from 37.8-9c, please tell me whats the ballpark temperature I should be in. Many thanks!
My specs are:
- Asrock fm2a75-itx
