G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
I need to only remove a small portion of mylar to do some touch-up work
underneath on a non-DP playfield. I do NOT want to remove the entire sheet
so that's out of the question. This mylar was apparently purchased and
installed later and not at the factory.
What is the best way to remove a 2" x 4" piece of mylar??? Can I cut a
guide line into the mylar first without damaging the pf then use the heat or
freeze spray method?? I do have a black line on the pf to follow.
Thanks for any input!
Mike S.
Kalamazoo, MI
Gameroom: http://tinyurl.com/4hfev
W C S Owner's List: http://tinyurl.com/39cjo
M B Scoop Repair: http://tinyurl.com/9lfu
Mike S.
Kalamazoo, MI
