Best way to set up a h60 cooler
Royatly
Commendable
Jul 19, 2017
27
What would be the best way to set up a h60 cooler. rear mount intake with 2 op mount outtakes, top mount outtake or any other way
I like to suggest having AIO cooler rads as exhaust. Doesn't make sense having the hot air from the radiators blowing hot air INTO the case. As for the location, that depends on the config of your other fans. Can you give more info on your case make/model and what fans you have?
Latest posts
