Hi Gurus,
Currently I am using 4 pc devices (htpc, laptop, and 2 desktops) at home, which I want to bring all of them under common shared network using a wired ethernet connection. Currently these devices are connected through my wireless router and the data transfer rates tend to be pretty slow down when I try to transfer large media content over the network. Also the transfer rates are very slow as opposed to copying the data between 2 devices using external storage media such as portable harddrives or jumpdrives. In this juncture, I am planning to purchase a wired router and a gigabit switch to setup a LAN to connect these devices. When I plug in the ethernet cable coming from the switch to the devices, the network connection will be automatically switched to Local Area connection bypassing the wireless connection. So in this situation, I need to do the following. Select the Local area connection when I want to transfer files between the devices and use the wireless connection for browsing the web. Right now I can only think of this solution with my limited knowledge on networking. Please suggest if there's any better way to handle both wired and wireless connection at the same time and transfer large files over the network without consuming the internet bandwidth. Also I am looking for a suggestion on wired router models around $50-100 range.
